586,113 active members*
3,081 visitors online*
Results 1 to 9 of 9
    May 2011
    91
    OSP5000M-G Backup
    Hello,
    I have the Okuma OSP5000M-G MC4VB. It run very good.
    Can I all backup the software from CNC to Floppy disk?
    Why on the list menu it have file Bin08-032-B.BBM and MEU02-C2-C.MPB but in the BB0 not have?
    Please you see the pictures.
    Thank you.
ID:	249940 Click image for larger version.
ID:	249942 Click image for larger version.
    Aug 2011
    419
    Re: OSP5000M-G Backup
    if necessary reinstall the software, you must purchase install software (probably one diskette) and its price is about 1000€ (only one or two file your recommended)
    May 2011
    91
    Can I backup all the software in the CNC to Foppy disk ? And can I use re-install it? If I can buy the software Bin.BBM and MEU.MPB
    Plaese sent to me email.
    Thank you
    Aug 2011
    419
    This files are special every machine. You can't backup all software CNC to Floppy disk.
    May 2011
    91
    Can I buy the sofware correct number of the machine ? And Where I buy?
    Thank you.
    Aug 2011
    419
    You can buy from local okuma dealer
    Mar 2009
    1982
    Since the machine works good, You better don't mess with software.
    If You need full backup, You must crack the Okuma CPU. It could be Motorola 6800 for such an old machine if you are lucky. Normally the mission impossible, there is an Okuma CPU used.
    Okuma doesn't support such an old machines anymore. Pricing for software, electronics is high. You take care of it, keep it clean. You check the contactors, relays and connectors in a regular base and this machine will serve You long years.
    You can backup all parameters, all user data, all tool data, all settings. This is very advised to do in a regular basis.
    May 2011
    91
    Hello Algirdas,
    Can you instruction for me full backup the software? I think the board duobble memory error I need the sofware re-install it.
    If have not software I don't know it how repair.
    Please send to me Email.
    My email: [email protected]
    Thank you
    May 2011
    91
    Hello Kurmay.
    Thank you very much for your help.
    If you have the software, please send to me.
    Thank you.
  1. OSP5000M-G MC-4VB
    By KHOATRANNGOC in forum Okuma
    Last Post: 07-23-2014, 02:36 AM
  2. HOW TO RUN RAMCON3 OKUMA OSP5000M
    By bbqa01 in forum Okuma
    Last Post: 11-09-2011, 10:24 PM
  3. OSP5000M-G sub program. Can't be done?
    By drjimmy in forum Okuma
    Last Post: 11-09-2011, 12:07 AM
  4. osp5000m
    By stonehengemfg in forum Okuma
    Last Post: 06-12-2010, 03:39 PM
  5. osp5000m parameter
    By Hwangbogeun in forum Okuma
    Last Post: 08-10-2008, 12:31 AM
