Sorry if this was posted else where on another forum, I searched but did not have any luck finding it.
I have a Union horizontal boring mill that has been retrofitted with a Fanuc 18i-Mb controller and a Siemens SIMOREG DC converter to control the spindle.
Recently I have encountered a problem with the M5 command in any program causing the machine to "hang". It reads the command, stops the spindle but the cycle start light is still illuminated.
I have to press the reset button to stop the cycle then search the program back to where I left off.
It appears that the cycle is not completing once it reads the M5.
I found a work around by removing the M5 from the programs and using the M00, M01 or M30 to stop the machine which seems to work.
Now I am experiencing a problem that the spindle shuts off during any cycle mostly after the machine has been on for over 2 hours. The machine will keep feeding which is creating major problems.
This has caused some major pain while tapping because the feed hold button is in-active during the tapping cycle. The E-STOP button is the only way to stop it but it is too late at that point.
I have contacted the machine tool company we purchased the retrofitted machine from and all I am getting is the run around.
Seems like they don't have anybody that is qualified to help solve the problem.
I am fairly intelligent with the understanding of the system and how it works but am not a technician by any means.
I was wondering if anybody has had similar experiences and could weigh in on areas to check besides the obvious (we have checked connections, feed back encoders, and other similar items).
Any feedback would be appreciated.
Thank you.
