Stalling X axis
I am running the HobbyCNC pro 4 -axis pro board, with 305oz-unipolar rating, 4.2v, 3A, 200 S/R, 3.2mH, Size #23, Dual Shaft, stepper motors. My screws are dual 1/2”, 8 /2-start on the X, single 3/8”, 8/2-start on the Y and 3/8” , 10 single start on the Z. I was running dual steppers on the X, and decided to go with a single stepper with 2 belts. Every so often when I hit the forward or reverse keys on the X, the stepper stalls. When it stalls, say in the forward movement, if I hit the reverse, it will move. Then when I hit the forward after going in reverse, it works. I let Mach calculate the steps per on the X and Y and it set it at 3200. I have the accel set at 40 inches per and the velocity set at 35. I am running the Dumpster Anti-backlash nuts and they seem to run free. I have checked for any mechanical binding, and found none. Why is the X stepper stalling.
Any help will appreciated.
Mike
Mike Kearns
noveltysigncarver.com
