586,121 active members*
3,243 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Gray Command Manager Toolbar??
    Sep 2014
    I am new CAMWorks and attempting to create tool paths. I am using the 2014 version of CAMWorks and made the basic drawing in Solidworks. The stock, machine and tool crib are all indicated, but the Command Manager Toolbar is gray'd out, see screenshot. I have verified and refreshed the license for the programs, but I'm stuck. Any ideas at this point would be greatly appreciated.
    Columbus/Indianapolis, IN
    Mar 2008
    111
    Re: Gray Command Manager Toolbar??
    My guess is that you are not licensed for the build date,
    I'd get in touch with your reseller.
    Apr 2012
    90
    Did you edit your machine definition and your stock in the tab shown? If you haven't done that you won't be able to do anything.
    Mar 2008
    111
    Machine is set, as is stock, extract mâché able features is not lit so it's definatley licensing, contact your resseler on Monday, or check your license version date and install a version that you are licensed for,
    If it was working and has suddenly stopped... The question is have you added or disabled any network devices?
    Sep 2014
    Success!! The license was in place, but the "CAMWorks License Info" was not defined. This is found just above the License Manager:
    Help > CAMWorks 2014 > License Info
  1. CNC manager/ tooling manager FLA COAST
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 05-05-2013, 09:01 PM
  2. Gray toolbar ???
    By MachineManiac in forum CamWorks
    Last Post: 04-28-2012, 02:08 PM
  3. Material Manager/Purchasing Manager - IL
    By MachiningJobs in forum Employment Opportunity
    Last Post: 05-23-2011, 04:04 PM
  4. Command Toolbar? etc.
    By cjdavis618 in forum Visual Mill
    Last Post: 11-23-2010, 02:11 AM
