586,036 active members*
3,543 visitors online*
    Aug 2010
    57
    Headstock Lubrication EZPath II
    In my manual it has a recommendation in one section for ONH-68 oil in the headstock. However, at the back of the manual in the cross-reference for oils and lubes, it only shows recommendations for ONH-32 and ONG-68 (which is mentioned elsewhere as the spec for the way oil). I was going to find some ONH-68 equivalent, but now I'm a bit confused on whether that's a misprint.
    What oil do you guys use in the headstock?
    Nov 2004
    3028
    Re: Headstock Lubrication EZPath II
    32 weight in the headstock.
  1. EzPath software?
    By klxrcr in forum Bridgeport / Romi Lathes
    Last Post: 08-16-2011, 07:11 PM
  2. help for ezpath ++
    By mmckell in forum Bridgeport / Romi Lathes
    Last Post: 01-29-2010, 04:21 AM
  3. Ezpath
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 02-17-2009, 07:04 AM
  4. EZPath II CSS problem
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2008, 07:43 PM
  5. ezpath fault
    By evo123 in forum Bridgeport / Hardinge Mills
    Last Post: 06-30-2008, 09:42 PM
