Re: Machining 4340 flame cut......Tips Anyone?
Aarghh!!!! My first tip is to farm it out somebody who is too naive to know what they are getting into.
I hope you have a nice big machine that can drive a big negative rake insert face mill taking a good depth of cut at a feed of about 20 thou per tooth running at around 600 fpm. Last time I did anything like this was over thirty years ago on a big manual Cincinatti using Kennametal KC850 inserts that were the cat's meouw back then; these days I don't know what grade is equivalent.
You need to get the stock cut at least 1/4" oversize and whatever machine you are using your depth of cut has to be deep enough to get under the hardened skin from the cut and your cutter and machine combination has to be strong enough to have a feed that gives a good big strongly deformed fast moving chip so all the heat from the cutting gets carried away in the chip.
It is also a good idea to hand grind a good bevel along all the edges so that when the inserts first enter the cut they are not impacting directly on the flame cut surface but have a chance to get underneath it and attack it from the back. You will find, if everything is going fine, that the inserts start to break down right along the region that is hitting the skin, deeper in the material the insert has an easier job.
