586,096 active members*
3,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1992 Haas VF1 dirve 149 spindle turning error
Results 1 to 3 of 3
    Jan 2012
    5
    "1992 haas vf1" im getting a 149 spindle turning error when I run the spindle. I use to be able to clear this with a power reset. (vfd drive) when the spindle is commanded to run the run light is on and the stop is blinking with o rpm in the display even though on the haas controller ive called out for 1250. ive called haas they think its the drive? any advise whould be greatly welcome, im very frusterated at this point. also id like to get some feed back on what drives are the best to replace this one!! it curently has a durapulse gs3 in there
    thank you for your help in advance
    Feb 2010
    1184
    Re: 1992 Haas VF1 dirve 149 spindle turning error
    Quote Originally Posted by srecord1 View Post
    Your local dealer will be able to set you up with the correct drive to use in your machine.
    I have never seen a Durapulse GS3 in a Haas machine. Can you post a picture?
    May 2012
    67
    Me neither, that must be custom. Has the machine ran in the past with this drive? If you think it's the drive that is bad PM me and I'll set you up with the right people to rebuild your spindle drive. Pics would also be great.
    Thank you,
    Phil
  1. Haas vf-6 error code 149 spindle turning???
    By millwright79 in forum Haas Mills
    Last Post: 09-20-2013, 03:09 PM
  2. 1992 Haas VF-2 High Power Ceramic Resistors
    By SadieD in forum Haas Mills
    Last Post: 03-28-2013, 10:06 AM
  3. Replies: 0
    Last Post: 04-02-2012, 04:22 AM
  4. 1992 Haas vf-2 this is insane...
    By mikemike^3 in forum Haas Mills
    Last Post: 01-05-2012, 03:15 AM
  5. Need 1992 Haas VF0 drive board ASAP!
    By jrudicel in forum CNC Machining Centers
    Last Post: 09-29-2007, 02:05 AM
