I'm setting up 2 motors for my x-axis. When I slave A off of X the A axis runs slower than the X. Both motors are identical with identical drivers and mechanicals. They are both running off of the same power supply. When I move both without slaving using MDI they both run at the same speed.
I'm running Mach3 using ethernet smooth stepper.
I am at a loss as to what the problem is.
