586,119 active members*
3,587 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > HardBlok or similar engine cement for filling mini mill column or base?
Results 1 to 13 of 13
    Aug 2014
    42
    I was thinking about ways to stiffen my Sieg X2 column and thought about filling it with one of the available engine block cements. That I'm aware of, these are cements with iron mixed in. They're used to fill the water jackets of racing engines. It has similar enough properties to cast iron for that application.
    I haven't found anything discussing these kinds of materials in this application. I would thing this would have the advantage of being machinable as well. I'd like to machine a channel where the current Z-axis rack is and install a lead screw there for improved Z-axis accuracy. I think if the column were filled this would not sacrifice much rigidity in doing this.
    Jun 2013
    1041
    Re: HardBlok or similar engine cement for filling mini mill column or base?
    I don't know if it will work but it looks like a reasonably safe bet compared to some of the epoxy granite mixes.
    Ben
    Apr 2004
    5737
    The question is whether it shrinks or not. If it does shrink away from the sides of the column, then it won't stiffen it. An expanding cement might be better.
    Andrew Werby
    Website
    Aug 2014
    161
    I don't think it shrinks. If it did it would be squeezing the cylinders around the pistons in an engine block causing possibly a 'cold' seize. I like the idea. I wonder about its self leveling properties. Just my thought on it I haven't done any reading about it but have heard of it. Good idea to use it for the mill column. I'd call their tech support and ask some questions.
    Jun 2013
    1041
    I did some reading before my first post. It is iron filled concrete so machining is iffy. As for shrinking it claims not to shrink away from the waterblocks it's used to fill. It also claims to hold up to the vigors and heat produced by the large engines it's used for as well as strengthening things.
    All and all I think it's well worth a try.
    Ben
    Aug 2014
    42
    The mixes I've found involve water. Some sources say water involved mixes leave pores which are less than ideal. Moroso specifically calls theirs a cement grout. Maybe an epoxy iron mixture would be more appropriate?
    Of course, instead of machining after setting I could use a mold which would leave a cavity for the lead screw, or just forget about running the lead screw in the column altogether.
    I think I'm going to give something like this a try.
    Aug 2014
    161
    Sorry my phone double posted.
    Aug 2014
    42
    I've found quite a few iron filled epoxies. Most claim good machinability and have a linear shrink ratio of less than 0.002:1. That sounds promising. They look rather expensive, so the engine block filler may be more economical, but I could likely add some grey cast iron filling as well by cutting up an engine block.
    Here's a few I'm looking at:
    Hapcast 3738 - HAPCO Inc.
    BCC BC7053 | Northern Composites | Process & Structural Compsite Materials
    Epoxy Casting Resins Specifications at Freeman Mfg. & Supply Co
    Casting Resins
    Sep 2008
    54
    What about adding steel rods (kind of like rebar) for extra reinforcement?
    Aug 2014
    42
    Quote Originally Posted by rbjem View Post
    I have an excess of engine blocks to cut up, otherwise I'd be all about it.
    Jul 2006
    11
    Any updates?
    Aug 2014
    42
    Quote Originally Posted by fxstc View Post
    Any updates?
    I got a job and moved states. It will be a while before I can put time into this.
    Oct 2009
    78
    Quote Originally Posted by burdickjp View Post
    Back when I racing in Top Alcohol I used B 11 Hydra Cal to fill my engine block water passages. B 11 has a slight expansion when set up and the alkali prevents rust formation. If I was to use plaster for creating mass in a machine tool void then I think that I would use B 11 with well pack gravel. In other words a lo tech approach to epoxy granite. The density of the aggregate is what is need where harmonics and flex are present.
    Ron
    Obama's Miracle > One pill will treat all of the old folk's health problems
  1. portland cement concrete machine base
    By js412000 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-28-2017, 07:02 PM
  2. How do you get the base of a mill square with the vertical column?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 07-14-2013, 06:16 PM
  3. X3 (Or similar mini mill) Rigidity Q
    By binfordw in forum Benchtop Machines
    Last Post: 03-19-2013, 01:44 AM
  4. Filling aluminum extrusions with concrete or cement
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 01-23-2009, 10:53 PM
  5. Filling steel tube with cement for damping/mass?
    By stag53 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-26-2007, 08:39 PM
