Although having separate 24vdc supplies for inputs and outputs may be considered ideal, I have never experienced a problem in using a common supply, Either use a common regulated 24vdc supply or if unregulated, make sure there is sufficient capacitance to keep ripple to a minimum.
If you set up a common ground plate and take the power supply common's and all shields to this common point, then this should take care of noise sensitive devices.
Al.
Albert E.
