586,119 active members*
3,400 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Trying to position table after program is over, won't work......Dura Vertical 5100
Results 1 to 6 of 6
    Sep 2014
    27
    I was told to type in G0 G90 G53 X-17 at end of program and this doesn't work. It's like something is overwriting it and the table just stays in the X position that the program finished at. Anyone have a idea whats going on?
    Jun 2008
    24
    Re: Trying to position table after program is over, won't work......Dura Vertical 510
    17 or 17.?
    Sep 2014
    27
    that was it, thanks. I figure it was something dumb that I was missing
    15362
    J10bucks
    Apart from the dot missing, you may be able to have a much shorter piece of code
    What are the lines of code that are before this move, if you have a G0 move for say the Z axes move it can be as simple as G53X17.
    So it would be like this
    G80G0Z3. (The G80 would only be there if you have just ended/done a canned cycle)
    M9
    M5
    G53X17. (you can include a Y axes move in this line as well if you need it)
    M30
    Mactec54
    Sep 2014
    27
    that works, thanks for all the help
    Feb 2009
    6028
    If this is something you do a lot of, you can also set up the G30 second ref return to park the table, or assign the M30 to a macro to park the table.
  1. Replies: 1
    Last Post: 06-02-2020, 04:58 PM
  2. Brand New Vertex Rotary Table Won't Work In The Vertical Position
    By Nelson_2008 in forum Benchtop Machines
    Last Post: 12-10-2012, 08:27 PM
  3. Mori Dura Vert 5060/5080/5100
    By underthetire in forum Mori Seiki Mills
    Last Post: 02-09-2011, 02:30 PM
  4. Mori Dura Vertical
    By chiz in forum Mori Seiki Mills
    Last Post: 09-09-2010, 12:39 PM
  5. Mori Seiki Dura Vertical 40 x 20 Model 5100
    By highspeedmike in forum Haas Mills
    Last Post: 06-26-2010, 01:44 PM
