586,347 active members*
3,518 visitors online*
Results 1 to 3 of 3
    May 2009
    107
    Need help with a Kwik-Switch 200 spindle
    My Boss 5 has a Kwik-Switch 200 spindle. The nut has not been working correctly and was stripped of all the springs and brass plug.
    I ordered a repair kit and supposedly have all the parts needed for a complete rebuild.
    It seems that the pins that hold the nut on the spindle have been stripped off and I need to figure out which pins, or buttons, are supposed to be there. I have never used a Kwik-Switch and while I understand it is supposed to be a tools free operation I do not know how the nut really works.
    Can someone tell me how the nut is supposed to work?
    Aug 2014
    889
    Re: Need help with a Kwik-Switch 200 spindle
    Attachment 250900
    I hope that helps.
    May 2009
    107
    Perfect ! Just what I needed... The instructions said something about a button needing to be depressed. There are more holes in the nut than I thought there needed to be and I was worried that I might be missing a button.... It looks like mine has the small locking pin sheared off and the previous owners were just using the nut as a regular collet nut.
    Thanks!
  1. Kwik Switch 200 spindle update
    By reabdet21 in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2012, 04:26 PM
  2. Kwik Switch 200 spindle
    Last Post: 10-21-2012, 10:57 PM
  3. Kwik switch 200 stuck
    By Meenbombs in forum Bridgeport / Hardinge Mills
    Last Post: 03-02-2012, 02:00 AM
  4. Excello CNC Mill with Kwik Switch Spindle ATC Options
    By bochek in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2009, 11:44 PM
  5. clattering kwik switch?
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2005, 05:03 AM
