586,089 active members*
3,915 visitors online*
    Sep 2006
    18
    fanuc 10m trouble
    I have a leadwell 760xl with a fanuc 10m control and at start up I get a ot100 alarm which in the book says spindle alarm turned on and the cause is 0 what does this mean and why can't I clear this alarm I have tried powering down all the way and reset also on the spindle drive the number 4 led is on were it says alarm codes any help would be greatly apprecaited
    Mar 2004
    564
    Quote Originally Posted by ezjn View Post
    I get a ot100 alarm
    OT usually means over-travel. Maybe your spindle axis has moved out of working limits, or you have a faulty limit switch..
    menomana
    24221
    I don't have my book here for the spindle alarm 4.
    The OT100 is just indicating the spindle is in an alarm condition.
    Check as much of the power supplies you can, including control fuses etc,
    Also see if you can find the test pins marked with +5, +12, or +24 etc, as there are often regulator IC,s in board, check with ref to the 0v pin.
    I may be able to get the code tomorrow if you still need it.
    Al.
    Albert E.
    Sep 2006
    18
    Al,
    Thanks for the help, I am not having any luck. If you can find the code tomorrow, it would be greatly appreciated. Justin
    Sep 2006
    18
    Thanks, for the help. I'll check that. Justin
