586,111 active members*
3,215 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > EX 1024 error in MV 40/40 MF-M6 mori seiki
Results 1 to 20 of 20
    Nov 2011
    17
    Hi
    Just imported a decently used machine from germany to india.
    Installed the machine, checked all the conections and powered up.
    Machine responds for all commands in mdi mode. But when set in auto mode and hit the cycle start button.. the machine pops up an error message as EX 1024 DOOR MUST BE OPENED ONCE.
    It is a manual door. Checked the front door switch.. side doora switch also.
    The inpuyt signals are working fine from the door switches.
    Closed and opened the door several times.
    Checked the keep relay settings also.. but the machine keeps giving the same error message.
    Any help or suggestion to solve the error would be appreciated.
    The door interlock bypass key is set to release side... but no use.
    Thanks and waiting for ur valuable help.
    Feb 2009
    6028
    Re: EX 1024 error in MV 40/40 MF-M6 mori seiki
    Door switch has to be on normal at boot. Estop must be released, then open and close the front door after hitting the OK screen at boot up. All other doors must be closed at boot up. This is just a door interlock switch check at power up.
    Nov 2011
    17
    Thank you underthetire for the advice.
    Done this but still getting the error.
    I have seen from your profile that u are a senoir level service engineer for mori.
    Pls help me set the B3 level safety for my machine. Total bypass all door interlocks.
    Its a moriseiki MV 40/40
    Sl no 4026.
    My mail id is [email protected]
    And [email protected].
    Awaiting for your reply sir.
    Feb 2009
    6028
    That would be a no way.
    Nov 2011
    17
    Hi
    Is that, u mean that bypass cannot be done...
    Feb 2009
    6028
    It can be done on some ladder versions, I just won't say how. No way am I taking liability for that.
    Nov 2011
    17
    Okk. I can understand. Thanks for the reply.
    Can i talk to you. Pls mail me ur contact number @ [email protected]
    Nov 2011
    17
    Hi
    Seeking more help.
    Iam not able to solve the EX1024 ERROR MSG. Pls anybody guide me through.
    My machine, though smart enough... iam not able to run it.
    Nov 2013
    22
    This massage must be occur when first power on machine to machine ready mode or push cycle start with auto mode on first time power on or after M2/M30 finish before.
    I don't sure that, Machine have this alarm occur when first time power on?
    Are you clear alarm on first power on?
    I have ideal for bypass it.
    But I think it not good solution.
    Nov 2011
    17
    Its not just on power on. But the alarm just pops up when i press the cycle start in mem mode.
    Till now i have not run my mcn on auto or mem mode.
    Pls help my mail id is [email protected]
    Nov 2013
    22
    Are you have Ladder Book?
    Normally ladder line of Mori Seiki Vertical machine Alarm EX1024 are checking for
    ---> No MDI mode + Work memory end M2/M30 + Cycle start
    But most machine generate alarm on you push cycle start when first power on without MDI mode.
    You must to sure that when you power on machine first you confirm to close the door once time because the memory status of M2/M30 must be on.
    You must to clear this step first.
    In the line of Work memory end, it has the function check of No door close check.
    I don't sure about status of Relay KA8 and KA9.
    Please check there too.
    Nov 2011
    17
    Yes sir.. u r almost there.
    We traced into ladder and found that the work end memory is not cleared. Hence it is giving EX 1024. DOOR MUST BE OPENED ONCE.
    Pls suggest how to clear the work end memory.
    Can i have ur mail id pls.
    Nov 2013
    22
    [email protected]
    Please send me about ladder picture too.
    Nov 2011
    17
    Okk sir
    Ladder pic of which address.
    Nov 2011
    17
    Finally Got The Machine Running, with Front Door interlock working. but for every M30/M02 the door key has to be removed and inserted again.
    Thanks to underthetire, kittiwat and all the group members for the invaluable inputs. Special Thanks to Revanna Patil and Srinivasulu ( engineers).
    Nov 2011
    17
    facing a problem with G16 code ( polar coordinates).
    When Gcode G16 is input along with program it gives an alarm 010 improper G code.
    in the manual it says its option code which is there fr MV 40B MF-M6 control.
    please help how to enable this.
    Nov 2011
    17
    I GOT ALL THE THINGS WORKING.
    SUDDENLY TODAY MORNING, ALL THE BACKUP GOT DELETED.... DONT KNOW WHY...
    BUT ENTERED ALL THE PARAMETERS AND STILL GETTING THE EX1047 ERROR.
    HOW TO CLEAR THAT.
    PLS SUGGEST
    Oct 2014
    28
    How to your precess for enter parameter and you sure enter all PMCPARA?
    Feb 2013
    4
    Quote Originally Posted by raokmk2003 View Post
    Kind to send me advise for this problem ?
    [email protected]
    Thanks Tu
    Aug 2019
    27
    HOW TO CLEAR THAT.
    PLS SUGGEST
    Can you send me the ladder of this machine please, i really need your help.
    Bagas
    [email protected]
  1. Mori Seiki Fanuc O-T Error EX357
    By hrhoward in forum Mori Seiki lathes
    Last Post: 06-11-2014, 04:30 AM
  2. Mori Seiki JR - ATC Error message?
    By shortlane in forum Mori Seiki Mills
    Last Post: 03-17-2013, 09:29 PM
  3. Mori Seiki MSC-501 - EX2060 Error
    By japi in forum Mori Seiki lathes
    Last Post: 11-13-2012, 12:14 PM
  4. Mori Seiki Fanuc 3T error
    By haitd in forum Fanuc
    Last Post: 03-08-2012, 08:51 PM
  5. Mori Seiki Lathe Error 414
    By KSDeerSlayer in forum Mori Seiki lathes
    Last Post: 09-20-2008, 01:33 AM
