587,047 active members*
2,695 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > TB6560 controller Spindle ON on power up OFF Mach3 Plunges
    Sep 2014
    10
    I have just installed TB6560 3 axis controller.
    As soon as i power it up my spindle starts running immediatly....even if PC is turned off.
    When Mach 3 runs Gcode the spindle travels to start point, plunges to start cut..then the spindle stops .....any ideas ?
    Thanks.
    Feb 2007
    966
    Re: TB6560 controller Spindle ON on power up OFF Mach3 Plunges
    Quote Originally Posted by Roy50 View Post
    Thanks.
    Sounds like you don't have a charge pump circuit, to turn off the bob when mach is not ready.
    Also, can you post the Gcode for that spindle problem ?
    Sep 2014
    10
    I have sorted the problem now all is OK.
    Thanks for the replies.
    Sent from my GT-P7310 using Tapatalk
    Feb 2007
    966
    What was the problem ?
    Sep 2014
    10
    Port setting in Mach3 ...Pin 14 was wrong.
    Now when I power up pc same time as controller its ok.
  1. Mach3 setup with TB6560
    By rwijbenga in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2014, 06:00 PM
  2. Mach3 and TB6560 setup
    By wh_izz1 in forum Mach Software (ArtSoft software)
    Last Post: 12-26-2012, 03:10 PM
  3. Another one who has problems with TB6560 in Mach3 :)
    By MLadegaard in forum Mach Software (ArtSoft software)
    Last Post: 10-01-2012, 09:00 AM
  4. tb6560 power
    By Denrow in forum Stepper Motors / Drives
    Last Post: 05-02-2012, 11:21 AM
  5. Spindle controller power on RESET
    By pilot001 in forum Fadal
    Last Post: 07-25-2011, 07:10 PM
