586,119 active members*
3,619 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > SolidCam; Transform; How to transform operations for individual parts
Results 1 to 13 of 13
    Nov 2010
    13
    Smile SolidCam; Transform; How to transform operations for individual parts
    So here's the problem:
    I have 50 same parts on one table side by side, I used transform function on solidcam - it transformed all operations as expected, but the problem is that I need to machine parts individually without jumping each operations to different parts, what I expect is that every part machining operations would be done for one part, and just then jump to next part. At this moment for example first operation is drilling holes - it drills on all 50 parts.
    Any suggestions? Thank you in advance!
    Oct 2007
    499
    Re: SolidCam; Transform; How to transform operations for individual parts
    This can be addressed by using sub-routines (or "procs" in SolidCAM speak) and setting up your post accordingly. Not something I have ever done so I can't be of much more use I'm afraid.
    Nov 2010
    13
    Well at this moment solution is to modify g-code using sub-routines of one part complete operations and just offset it with rapid move and G92 X0 Y0, but I dont think it is the way to do this... I was reading about translate-transform function properties meniu, anyone know how to access to that settings?
    Jun 2009
    12
    All you need to do is select all operations you want to transform and only then select the option "transform".
    You may use matrix option, which seems to be the best for your case.
    Regards,
    Nov 2010
    13
    Hi, thank you for reply,
    I did this earlyer, and did it again now - it process one operation on all transformed parts, what I need is to process all selected operations on one at the time, of all transformed parts. Any ideas?
    Like on your example, you have two contours, what transforming does is it makes first contour on all 50 parts, and just then goes to contour nr.2 on all parts.
    Jun 2009
    12
    Depending on your Solidcam version, that might be correct. Try upgrading your Solidcam to the latest version available.
    I have just tried in mine and it did all operations before moving to another part. I have the latest version of Solidcam.
    Another thing that you could be doing wrong is selecting individual operations to transform.
    Again, if you have the Solidcam updated, select all operations in first place and then click on transform.
    Hope it helps.
    Nov 2010
    13
    What version are you using?
    Jun 2009
    12
    2014 sp2 hf1
    Oct 2013
    153
    Laramaviper if you do all the operations with single tool solidcam will transform all the operation together coz its same tool . That's nothing to do with the version !
    Nov 2010
    13
    Upgrading to latest version solved problems, thank you for help!
    Oct 2013
    153
    Is it worked ? Are you using single tool ? How many tools you have in the program ?
    Nov 2010
    13
    Yes upgrading worked. Single tool on workpiece and program.
    Oct 2013
    153
    I thought you wanted to do all the operations with different tools in one part first . Any way the new version is much better .
  1. Solidcam transform toolpaths around 4th axis problem?
    By jsclark in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-01-2014, 10:44 PM
  2. More transform help
    By orion_134 in forum Mastercam
    Last Post: 01-20-2014, 01:02 PM
  3. solidcam 2010 no transform for machine Hurco
    By Bogdan_Celtic in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-29-2013, 12:06 PM
  4. Replies: 5
    Last Post: 03-18-2012, 09:17 PM
  5. Transform in NX6
    By mongo46538 in forum UG NX
    Last Post: 12-16-2009, 04:27 PM
