My problem started with the machine not wanting to start and giving 2001 error operational panel. The problem was intermittent. So the last time I got it to come up I decided to just leave it on until I finished the job it was running. This was working fine until the power went out. Then it wouldn't come back up. I replaced the operation panel but did not fix the problem. I replaced the CRP board and the cleared the error and it boots up. But now the spindle has a strange problem. If I MDI M3 S2000 it starts normally and seems to be ok. If I MDI M3 S1000 it runs counterclockwise. If I MDI M3 S2000 and start it and then start turning the override knob down, when it gets below 1000 RPM it stops and starts turning counterclockwise. Then the further I turn it down the faster it runs going counterclockwise. If I turn it back up it switches to clockwise again. Does anyone know what is causing this. The spindle had no problems before this. I don't know if there was some kind of power spike when the power went out or what.
Dave
