586,117 active members*
3,414 visitors online*
    Jul 2010
    5
    Gecko G540 DB9 to bipolar stepper wiring
    Greetings,
    I can be very dense at times, I cannot seem to correlate the terms A, A/, B, B+ (stepper diagram) to A+, A-, B+, B- (G540 pinout table). There are a few previous discussions that address, but the stepper wire colors they reference are different
    Could someone more experienced at reading wiring diagrams and wiring steppers take a look at the diagram and tell me if I have the wires/pins correct? Thanks in advance!
    Gregg
    Mar 2007
    2083
    Re: Gecko G540 DB9 to bipolar stepper wiring
    Hi Gregg
    since the wire colours used are not the same on all motors
    use a multimeter to check for continuity between the four motor wires
    once you find the 2 wires going to each coil you can wire one coil to A+ and A -
    and the other coil to B+ and B -
    without the data sheet for the motor you don't know the phasing of the motor windings
    and you may have to change the motor direction active high / low setting in mach 3
    to get the motor to rotate in the correct direction when you set up your machine
    John
    Oct 2014
    4
    I have a 4 wire (8 total wire ends) motor. I have the basic red, green, black and blue wires. Then there is the white and brown. The brown is a motor ground...no worries there. Not sure how to it relates to the controller though. the white is all of the end leads (common ground) and not sure where to connect that one. Do they have pin assignees? Are they just grounded on the controller some how? Where do they belong? Attachment 253626
    Jul 2010
    5
    Please forgive belated reply. I do have the wiring diagram (tried to attach). I guess what you are saying is: hook it up one way or the other and then change rotation if required.
    Jul 2010
    5
    For some reason I don'Attachment 253646Attachment 253646t think the diagram I tried to attach worked the first time
  1. 6040z Gecko g540 conversion wiring question
    By greeziakattack in forum Chinese Machines
    Last Post: 11-20-2015, 03:41 PM
  2. Planet CNC USB Mk2 Controller + Gecko G540 driver wiring
    By lingo124 in forum Open Source CNC Machine Designs
    Last Post: 06-24-2013, 06:59 AM
  3. G540 w/ 8wire stepper running bipolar parallel
    By dxhale in forum Gecko Drives
    Last Post: 03-27-2012, 04:11 AM
  4. Wiring Gecko G540 to PSU
    By rnm85 in forum DIY CNC Router Table Machines
    Last Post: 01-08-2012, 02:48 AM
  5. Minimum wiring connections for Gecko G540
    By CNC Lurker in forum DIY CNC Router Table Machines
    Last Post: 12-09-2011, 10:30 PM
