586,062 active members*
4,884 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad lathe outputting radius instead of chamfer
Results 1 to 7 of 7
    Oct 2003
    128
    I have a simple boring operation that has a couple of small chamfers, Instead of outputting the chamfers Bobcad is outputting radius's in the code. And my lathe (Fanuc control) is ignoring that part of the program. No error's, just ignores that area of the part.
    Any ideas?
    Marc
    Jun 2007
    394
    Re: Bobcad lathe outputting radius instead of chamfer
    Can you post the suspect code and image of the toolpath
    Oct 2003
    128
ID:	252160Click image for larger version.
    The code and .bbcd are in the zip file (fisrt post)
    My lathe just ignores the moves at the top
    Marc
    Apr 2008
    1577
    Hey Marc, I took a look and I think I see what is going on. When System Compensation is on the toolpath is going to "roll" over at all the hard edges of two intersecting lines, including chamfers. You can see that in the closeup above in your screenshots when it encounters the second chamfer. This is the first time I've looked at a BobCAD lathe file so I hope someone corrects me if I'm wrong but that's what I see as I played with the allowances and the tool nose radius.
    Attachment 252176
    When BobCAD offsets the toolpath for your tool allowance and trims it to the Z value (4.99) of the selected geometry, the length of the chamfer ends up measuring only 0.005" long. You can also see (in the pictures below) that when the System Compensation is applied (using the tool nose radius) and it rolls over that first edge, the difference between the path I drew manually and the toolpath BobCAD comes up with is close enough that the first line is eliminated and becomes one single arc - the rollover. This is happening because of the general allowance allowed by the system and the calculations doing the offsetting. If you could measure the variation between the two, it's probably less than that tolerance.
    Attachment 252178
    If I don't change anything else in your file and go to Preferences - Settings Part - System and change the Lathe tolerance to 0.0003" I manage to get a linear move at the very beginning of the bore. A lot closer to what I think the path should be but I would instead simply extend the chamfer out into air by drawing a line at an angle (Line - Angle - Relative to Entity) of 0° at least the length of your tool nose radius. That will force a linear move at the beginning, long enough to not get "toleranced" out by the System Settings and nothing else in your code should change.
    Jun 2008
    1838
    Marc
    SBC is correct, BC doesn`t work right on System Compensation, I always turn it off when using Fanuc (0T in my case) controls, if you turn off the System Comp in BC and use your tool offsets and TNR in your Fanuc control you shouldn`t have any issues
    See image for toolpath without System Comp
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Oct 2003
    128
    Thanks SBC & Rob,
    I'm just getting up to speed on the lathe, so taking little baby steps
    I will give that a try later. I did find my biggest problem was I had the Z tool offsets fubar so the boring bar was cutting air. Got that handled so back at it.
    Marc
    Jul 2008
    70
    Quote Originally Posted by The Engine Guy View Post
    Marc
    Regards
    Rob
    I do the same turn off system comp and machine comp
  1. Milling a radius using BobCad V25
    By RMW in forum BobCad-Cam
    Last Post: 05-15-2013, 04:48 PM
  2. BobCAD v23 - Tool nose radius comp problems
    By RJoubert in forum BobCad-Cam
    Last Post: 03-05-2012, 06:56 AM
  3. Bobcad tool nose radius
    By copperman in forum BobCad-Cam
    Last Post: 01-14-2011, 07:20 PM
  4. chamfer into radius
    By Tucker84 in forum RFQ Feedback
    Last Post: 12-05-2009, 05:20 PM
  5. chamfer into radius
    By Tucker84 in forum Haas Lathes
    Last Post: 10-29-2009, 02:26 AM
