586,113 active members*
3,545 visitors online*
IndustryArena Forum > CAM Software > CamBam > Creating dxf, importing to cambam, error
    Sep 2008
    Using Autocad 2014 to make new mounts for my router, used region and subtract commands for the first time and I am getting 'unhandled entry: region' when I open the file in cambam. So I made the part again, still get the error in cambam. I am a newbie so I am sure it is something I am doing wrong. Please let me know. I have the file attached.
    Thanks for reading!
    Jun 2013
    1041
    Re: Creating dxf, importing to cambam, error
    I can't seem to download your file. I'm assuming it's a 2d file? If so in autocad try using the explode command on the regions before saving and exporting.
    Ben
    Sep 2008
    WOOO! Thank you so much, exploding it did the trick.
  1. Replies: 9
    Last Post: 01-01-2014, 06:47 PM
  2. Replies: 6
    Last Post: 06-05-2013, 05:06 AM
  3. Confused with CamBam drill error...
    By kievari in forum PCB milling
    Last Post: 08-22-2011, 08:13 PM
  4. Importing CamBam Gcode into Kcam
    By hondaman900 in forum Uncategorised CAM Discussion
    Last Post: 05-23-2010, 07:31 AM
  5. Importing DXF in PM turn error mess.
    By LeeWay in forum Dolphin CAD/CAM
    Last Post: 08-30-2008, 08:54 PM
