586,100 active members*
3,113 visitors online*
    Dec 2012
    8
    Smile CNC lathe with Y axis and Live tools or not?
    Hola de nuevo!, almost a year later I'm here again! in 2013 I asked if the 4th axis in a VF1 was a good idea to include it in the package., now I want to buy a CNC Lathe but the question is, should I consider the Y axis with live tools or not?, probably you are thinking that I shall know the answer according to the pieces usually we made., if the answer should depend it on this., then a 2 axes lathe is enough to perform our work because we have a 4th axis in the Haas VF1., but I want to know according to your experience if the Y axis and live tools in a lathe helps more, reduce time, etc or if you prefer to use a 4th axis than a Y axis?
    We want a CNC lathe because last month a customer ask if we have the capacity to produce 1500 bushing pieces per week the dimensions were 2" external and 1 3/4" internal and the longest dimension was 2.5"., our answer was unfortunately No:nono:., then now we are thinking in a Haas ST-10Y, what do you think about this option?:idea:, We made a lot of pins with several dimensions as per example: 4 mm external diameter x L= 10 mm and M3 internal thread all in stainless steel.
    Regards,
    Z
    Nov 2014
    Re: CNC lathe with Y axis and Live tools or not?
    Hola Z, we are a professional manufacturer of CNC lathe and machining center in China. Pls check out here JASU cnc machine tools, bottle blowing machine manufacturer & supplier from China-JASU
    If any interest in us, pls contact me.
    Kind Regards
    Hilda Li
    Email: [email protected]
    _____________________________________________
    www.jasucorp.com
    Jun 2015
    Here is a California based CNC company that has been selling 2-axis turning centers. Heard some pretty good reviews on them but I haven't heard about one with live tools, though. Might be worth checking out Kent CNC.
  1. Aluminum Round Part on Lathe with Live Tools
    By GaussianRule in forum North America RFQ's
    Last Post: 10-30-2012, 04:31 AM
  2. 3 axis lathe with live tooling
    By cvmachinist in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2012, 07:40 PM
  3. Replies: 0
    Last Post: 02-18-2011, 04:06 PM
  4. Live tools only or Y-Axis?
    By grweldon in forum MetalWork Discussion
    Last Post: 11-19-2008, 03:26 PM
  5. Haas Lathe TL-25B with live tools
    By LONERO in forum Haas Mills
    Last Post: 09-30-2008, 11:52 PM
