Hi guys;
I'm from France (so sorry if my english is not as good as your's ), and i'm there to find some informations about a project.
First of all, i'm a technician who install cnc machines for cabinet manufacturing (with ATC and drilling head), edge banders, saws with sliding tables, and so on.
I recently had the opportunity to get a 2.5-3D cam software, including the training (similar with artcam, alphacam, mastercam....)
But my problem comes from tools, and cutting speed.
I bought 2 ball end mill, 2 teeths, carbride, ø25 and ø8 from Leitz.
The spindle power is about 8KW, 24.000 rpm max.
I want to mill some pictures with relief on MDF pannel 19mm thickness, size 500x500mm
I made a rough in one step with the ø25 bit (maximum depth was 10mm), step 0.2mm @18000 rpm, 6m/min
The finish was made with the ø8mm bit, step 0.2mm @22 000 rpm; 6m/min also.
The result was not that good, i mean that the relief wasn't that pronounced, and it took me approximately 2 hours to mill the pannel (rough+finish).
My question is, could you give me some advice to mill 2.5D pannel faster, and get a better result?
I'm not removing that much material,so for me it could be milled much faster. (i would like to do it in half an hour)
The machine can easy support more working forces (1300w servomotor in X rack and pinion, 1100w in Y ball screw, 900w in Z with ballscrew, 8kw HSD spindle).
Total weight of the machine is 3700kgs.
Thanks a lot for your answers
