586,108 active members*
3,218 visitors online*
    Mar 2006
    36
    Power Supply Questions
    I found the PMDX-135 Power Prep Module and was thinking about using this as part of my Power Supply.
    http://www.pmdx.com/PMDX-135/index.html
    Is anyone using this module that can give me some feedback?
    I also found the CandCNC ACM-100 and thought this might be a nice and easy component to use to for controlling incoming AC Power. CandCNC also has a DC Power Breakout board.
    http://www.candcnc.com/DCM-100.htm
    Would using both the PMDX-135 and DCM-100 work together or is this just redundant and make absolutely no sense?
    I haven't made a final desicion on the Servo Drives that I want to use but I am most likely going to using the MCG 33003 Brush Servo motors 800 oz-in.
    Any thoughts would greatly be appreciated. Elecontronics are still a bit of a black art to me.
    May 2005
    2502
    They strike me as redundant.
