586,103 active members*
3,304 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Itty, Bitty Hall Effect Limit Switches
Results 1 to 6 of 6
    Feb 2006
    7063
    A while back, I designed up some small Hall Effect limit switches for the Torus Pro. These use small (TO92) three-terminal Hall Effect sensors - the same kind I use in the Torus Pro PDB. They are inexpensive (under $1 each), and very accurate and repeatable. They are triggered by the South pole of a small (5mm dia x 1mm thick) Neodymium disc magnet. They can be triggered by pushing either end of the pushrod about 01", so can be setup to use only one switch assembly per axis, or two. The only part I haven't made yet is the "flags" that attach to the pushrod, and hold the disc magnet. The sensor itself is epoxied into a small pocket milled into the back cover, with the three wires, also epoxied in place, coming out the side. A pair of small coil springs provide self-centering of the pushrod and flag.
    Here is the assembled view. The housing is three pieces - a 1/8" thick back cover, 3/8" thick center piece, and 1/8" thick front cover.
    Attachment 252386
    With the front cover removed, you can see the pushrod, the pockets on the left and right to locate the two coil springs, and the pocket in the back cover for the sensor and wires. The three housing pieces will be sealed with a good sealant, like Hylomar. The flag will be pinned to the center of the pushrod.
    Attachment 252384
    Regards,
    Ray L.
    May 2009
    327
    Re: Itty, Bitty Hall Effect Limit Switches
    OK I will take 3,...
    Dec 2013
    72
    What kind of accuracy are you expecting for homing/limits with these?
    Feb 2006
    7063
    In playing with the sensors a few years ago, they appeared to be good to at least a couple of tenths.
    Regards,
    Ray L.
    Apr 2005
    1268
    Ray;
    Are you going to sell these sensors?
    Kind of like the design.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Feb 2006
    7063
    Bill,
    I have no interest in selling them, but I will post the models, and you can make your own. They're pretty easy to make.
    Regards,
    Ray L.
  1. Replies: 15
    Last Post: 11-10-2014, 03:29 PM
  2. hall effect home switches
    By daniellyall in forum Mach Mill
    Last Post: 10-27-2012, 02:10 AM
  3. Is anyone using hall-effect limit switches?
    By RomanLini in forum DIY CNC Router Table Machines
    Last Post: 02-28-2010, 08:53 PM
  4. Hall Effect Limit Switches
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 09-06-2009, 02:12 AM
  5. Hall Effect Limit & Zero
    By Trebleplink in forum CNC Machine Related Electronics
    Last Post: 10-20-2007, 12:08 AM
