586,060 active members*
4,275 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > tapping 2024 t351 alluminum
    Apr 2008
    6
    I have a Haas vert. mill with rigid tapping. We do a lot of tapping with this machine from 4-40 to 1/2-13. We mostly use the 4" ext. taps from Kenametal which are spiral point. I want to push the machine to the max and also the tap. I just don't know where to start. with speed. I have been running a 1/4-20 at 1000rpm and a feed of 50 ipm. any suggestions?
    May 2010
    62
    Re: tapping 2024 t351 alluminum
    What coolant/tapping fluid are you using? Blind holes, or through? What sort of tap holder?
    I use a floating holder, and often tap metric stuff a little over 1500 rpm, with nary a problem. Likely could go faster..... I also like to use forming taps in aluminum, especially blind holes.
  1. 2024 Aluminum
    By millford_turnny in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2012, 05:49 PM
  2. alluminum CNC machine to get?
    By burb1999 in forum Uncategorised MetalWorking Machines
    Last Post: 01-15-2011, 06:48 PM
  3. Milling alluminum
    By mikey74063 in forum MetalWork Discussion
    Last Post: 07-22-2010, 04:43 AM
  4. My second CNC router out of Alluminum (bigger)
    By jimmyaz in forum CNC Wood Router Project Log
    Last Post: 03-11-2008, 12:11 PM
  5. Air Cutting Stainless and Alluminum
    By denmcdsk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2007, 10:00 PM
