Hey, I'm having a problem with the ATC turret in a Fadal 4020fx machining center with a Fanuc 0iMC controller.
I Don't know how it happened because I wasn't the one operating the machine at the time, but I'm the one that has to fix it
Somehow the tool numbers in the ATC turret changed. Like, Tool 1 is now tool 2, Tool 12 is now tool 13, etc., and the current situation is the following: there is no tool in the spindle (tool 1) there is a tool in the turret (tool 1), so, whenever a tool change command is executed, the machine first tries to release Tool 1 (empty spindle) in its assigned pocket, resulting in a crash because there is already a tool in that slot.
I used M11 to reassing N1 slot , but this only works whe the loaded tool and the turret slot number match, so it is useless in this situation.
What can I do? I'm going crazy here
