586,051 active members*
3,983 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    15362
    Re: VFD Error Code
    Quote Originally Posted by steve78 View Post
    i find i have the same problem..i have disconnected every cable apart from the 240v input and it still comes up with e30.1 does this mean the vfd is toast or maybe the rfi filter thats inline just before it
    any help appreciated
    What is the VFD you have, I guess it is the same as in this post, then check how you have it wired, in the UK you would have, ( 1 Hot ) Neutral and Ground / Earth connected, this is different from the USA, which is what the first post is about
    Mactec54
  2. #22
    Dec 2016
    4
    Re: VFD Error Code
    its a hitachi wj200 it has been working fine with a 24000 rpm chinese 2.2kw spindle . then the error came up . as said i plug everything apart from power in and it still has the error code
  3. #23
    15362
    Re: VFD Error Code
    You will have to clear the fault, follow the manual on how to do this,\
    To get this fault, you may not have set the correct Parameters in the VFD that suit your spindle, this is the normal cause of problems like this, wiring also can cause this problem
    Have you checked the spindle Ground / Earth connection, Pin #4 has to be connected to the spindle most are not and need to be corrected
    Mactec54
  4. #24
    Dec 2016
    4
    Re: VFD Error Code
    thanks for the help but i have read the manual and i cannot find how to clear the alarm error code if any knows how that will be a great help
  5. #25
    15362
    Re: VFD Error Code
    You will have to fix your wiring, even if you are able to reset the VFD, post some photos of your wiring, do you have shielded cable for the spindle, and is the shield correctly terminated
    Only some of the manuals have this information
    Mactec54
Page 2 of 2 12
  1. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  2. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
  3. G code error with CAM
    By greeps in forum Dolphin CAD/CAM
    Last Post: 07-02-2011, 03:44 AM
  4. error code 017
    By musnar in forum HURCO
    Last Post: 10-13-2009, 02:20 PM
  5. ps 101 error code help!
    By AC_Engineering in forum Bridgeport / Hardinge Mills
    Last Post: 11-13-2007, 01:01 PM
