586,108 active members*
3,084 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Fanuc AC Spindle Drive speed does not match S-code speed
    Jan 2008
    78
    We have an Hatichi 25S turning center, with a Fanuc AC Spindle Drive A06B-6044-H039. The drive was repaired by Fanuc and is working, but the S-code spindle speed commanded does not match the displayed spindle RPM on the screen. When a speed of S3000 is commanded, we see an RPM of approx 3300, a difference of about 300. Spindle speed override set at 100%
    How can we make the speed match the S-code?
    Cheers,
    Steve
    Re: Fanuc AC Spindle Drive speed does not match S-code speed
    Set the spindle to run at a commanded speed.(The spindle unit displays MOTOR speed not spindle speed).
    1. Hold all four buttons until FFFFF flashes.
    2. Release all buttons.
    3. Hold MODE button in while pressing either the Up or Down button.
    (The parameter number will be displayed in order i.e. F01,F02,etc.)
    4. Release the MODE button.
    (The Parameter value will be displayed) Arrow up or down to change the value till the spindle speed matches the programed value.
    F-13 RPM Adjustment of Forward Rotation.
    F-14 RPM Adjustment of Reverse Rotation.
    Stop the spindle and press DATA SET on the spindle drive to save your changes.
    Jan 2008
    78
    drdos,
    I can not find any pb's or display LEDs on my spindle drive, so it would seem you are thinking of a different drive. But thanks for trying.
    Cheers,
    Steve
  1. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  2. Fanuc 5T Spindle Drive Speed
    By Dragoon2 in forum Fanuc
    Last Post: 12-25-2009, 03:49 AM
  3. Spindle speed command from G-code
    By ddanutz1 in forum Excitech routers
    Last Post: 08-12-2009, 04:16 PM
  4. Set & Max Spindle speed code ?
    By Jami9104 in forum Fanuc
    Last Post: 06-13-2008, 11:37 AM
  5. fanuc 16i-m high speed G code ???????
    By ramazan318186 in forum Fanuc
    Last Post: 07-23-2007, 05:08 PM
