586,655 active members*
2,841 visitors online*
Results 1 to 2 of 2
    May 2012
    31
    Servo Motor Encoder Enclosure
    I am in the process of replacing the X and Y axis servo motors and encoders on my Industrial Hobbies CNC Mill. I am using the 850 oz/in Keling technology KL34-170-72 servo motors equiped with CUI AMT-102 or AMT-103 encoders. I am retaining the 4:1 pulley ratios and thus using 250CPR Amt-102/103 encoders with quadrature results in the same overall mill Counts Per Inch of 20000. The cover for the encoder was made from thick walled aluminum tubing found inexpensively on eBay. The outside diameter of the tubing was 3.5 inches and the inside diameter was 2.5 inches, giving plenty of room for the AMT-102/103 encoder. The end cover is 0.08 inch aluminum disks again found inexpensively on eBay. The aluminum tube was turned on my Logan 400 Lathe and the end cover was drilled on my Taig cnc mill for the 5-40 thread button head screws. The finished encoder cover was glued to the servo motor with polyurethane glue. This is a simple and easy enclosure to make. The 3D CAD drawings can be found on GrabCAD in .stp format:
    https://grabcad.com/library/servo-mo...er-enclosure-1
    Attachment 252842Attachment 252844Attachment 252846Attachment 252848Attachment 252850Attachment 252852
    Nov 2003
    287
    Re: Servo Motor Encoder Enclosure
    Nice Job.
  1. Runaway Servo Motor - Bad Encoder?
    By purple_jeep in forum Servo Motors / Drives
    Last Post: 07-11-2013, 12:35 AM
  2. encoder cable/servo motor
    By gardon in forum Colchester Tornado lathes
    Last Post: 06-02-2012, 04:25 AM
  3. Need Help --- Servo motor with heds encoder
    By EyeQ in forum CNC Machine Related Electronics
    Last Post: 02-28-2011, 01:38 PM
  4. Servo motor and encoder. How to debug?
    By ESjaavik in forum Servo Motors / Drives
    Last Post: 06-20-2004, 11:37 PM
