586,075 active members*
4,103 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Software for complex g-code generation
    Aug 2014
    18
    Guys, I'm almost building my CNC. I came up with a question. Say I have a complex geometry that needs to have some drawings on top. Assuming I have the slt drawing of this figure.
    This geometry may be flat surfaces, curved, etc. .. If I wanted to just write or draw little lines on the surface .. the CAM software can do this?
    In other words, I have as input the complex geometry and the lines need to be drawn on the surface (if I can do engraving on the surface where I need to pass the drill).
    In the end, cnc machine would just go the route of the line on the surface (being any type of surface: regular, irregular, etc).
    I saw the videos on youtube, usually the part to be machined is a rectangle or a general surface. In the CAM software I can insert my custom initial geometry?
    Look for example this computer mouse, I would insert the STL model of the mouse as initial geometry (which will be machined) and the STL model of the mouse --->already machined<---. Finall, the CAM software would generate just the drawing on the picture (the skull **)
    Can CAM softwares do it (just engraving on the general surface)?
    Attachment 252890
    Thank's
    Aug 2014
    18
    Re: Software for complex g-code generation
    If yes, can you tell me some softwares for that?
  1. Setting dimensions for complex artwork and software selection
    By navkamals in forum WoodWorking Topics
    Last Post: 03-31-2013, 09:20 PM
  2. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum News Announcements
    Last Post: 12-19-2012, 04:37 AM
  3. G-code generation software
    By DJR in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2011, 02:20 PM
  4. G Code Generation
    By robbycar in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2004, 01:10 PM
  5. G-Code Generation
    By kcoaks in forum DIY CNC Router Table Machines
    Last Post: 04-06-2004, 12:23 PM
