586,076 active members*
3,802 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > CAM software for drawing on the surface
    Aug 2014
    18
    Guys, I'm almost building my CNC. I came up with a question. Say I have a complex geometry that needs to have some drawings on top. Assuming I have the slt drawing of this figure.
    This geometry may be flat surfaces, curved, etc. .. If I wanted to just write or draw little lines on the surface .. the CAM software can do this?
    In other words, I have as input the complex geometry and the lines need to be drawn on the surface (if I can do engraving on the surface where I need to pass the drill).
    In the end, cnc machine would just go the route of the line on the surface (being any type of surface: regular, irregular, etc).
    I saw the videos on youtube, usually the part to be machined is a rectangle or a general surface. In the CAM software I can insert my custom initial geometry?
    Look for example this computer mouse, I would insert the STL model of the mouse as initial geometry (which will be machined) and the STL model of the mouse --->already machined<---. Finall, the CAM software would generate just the drawing on the picture (the skull **)
    Can CAM softwares do it (just engraving on the general surface)?
    If yes, Can you tell me some softwares for that?
    Attachment 252890
    Thank's
    Re: CAM software for drawing on the surface
    G-Code Ripper
    Some CAM software can project the drawing onto the curved surface. Vectric's Aspire can do this.
    Feb 2007
    711
    I think many softwares will do that, a google search of "project toolpath" shows mastercam, aspire, surfcam, artcam, etc..
    How do you know your model matches reality though?
    I think the best option is probing the surface to be machined in the CNC control, then transforming the toolpath onto the probed surface.
    I have used probekins in linuxcnc to do this. I think another software is "Warpdriver" though I have never used it. another is "Autoleveller"
    Aug 2014
    18
    Ger21, Vectric can do this to curved surfaces? irregular?
    Aug 2014
    18
    in other words, would like to follow a path of a cnc robot welding .... using a cnc to follow a path... https://www.youtube.com/watch?v=HUU3HdxOqZs
  1. drawing on a 3d model surface
    By --> in forum BobCad-Cam
    Last Post: 11-02-2013, 12:01 AM
  2. What circuit drawing software?
    By tony ennis in forum CNC Machine Related Electronics
    Last Post: 06-27-2009, 01:21 AM
  3. Replies: 1
    Last Post: 06-20-2008, 08:30 AM
  4. 2D drawing software
    By chrugel in forum OpenSource Software
    Last Post: 03-23-2008, 07:00 PM
  5. drawing software
    By mike46 in forum Uncategorised CAD Discussion
    Last Post: 12-19-2007, 02:59 PM
