Hi guys, my 2.2kw spindle gets a bit warm when running for over 20'. I leave it running for 1h 30min and it gets warmer.
The cooling system I use is a Eheim 600 Alpha Cool watrer pump, which is a bit small. Water pump also gets a bit lukewarm. Should I replace this water pump with a bucket of water? If so, can I get the inside part of exisitng Eheim water pump and put it in the bucket?
Thanks.
