586,106 active members*
3,159 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 2.2kW water cooled spindle is getting warm
Results 1 to 3 of 3
    Apr 2009
    220
    Hi guys, my 2.2kw spindle gets a bit warm when running for over 20'. I leave it running for 1h 30min and it gets warmer.
    The cooling system I use is a Eheim 600 Alpha Cool watrer pump, which is a bit small. Water pump also gets a bit lukewarm. Should I replace this water pump with a bucket of water? If so, can I get the inside part of exisitng Eheim water pump and put it in the bucket?
    Thanks.
    Oct 2009
    15
    Re: 2.2kW water cooled spindle is getting warm
    I have a 2.2 that I run with a bucket of treated water. It has always kept it cool for me. I was considering putting a chiller system I it but have yet to find any reason to do so.
    Oct 2006
    84
    Define "warm"... What's the actual temperature?
    What size reservoir do you have?
    Also, IMO that pump is fine. 600LPH/150GPH seems to be plenty... do you even have a single gallon in your entire cooling system?
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. Water Cooled Spindle
    By sylvan in forum CNC Tooling
    Last Post: 09-03-2011, 12:20 AM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
