586,113 active members*
3,235 visitors online*
    Aug 2014
    DIY CNC Improvements
    Hi Guys,
    I have been working on my homemade CNC and looking for a solution about mounting the belts to the gantry. Could you please share your experience how you mount the timing belts? I am using open loop belts and using a wooden piece to mount the belt to gantry. The problem is the tightening phase, it is really hard to tighten in place.
    Thanks for the answers in advance.
    You can see how I did it in my blog: DIY Projects
    also a video of my cnc in youtube
    May 2005
    3920
    Re: DIY CNC Improvements
    Generally you need a way to take up slack. Either a pulley that can be moved or an idler someplace in the system.
    Feb 2009
    192
    A spring loaded idler (tensioner) would be a good option. If you have a spare bearing somewhat wider than your belt this would work fine. Check out the belt tensioner used on your car, it doesn't have to be that elaborate but it will give you a nice starting point for your design.
  1. Speed improvements
    By Michaelofburien in forum DIY CNC Router Table Machines
    Last Post: 01-05-2014, 05:39 AM
  2. Improvements in Winmax 8 vs 7
    By gthlm in forum HURCO
    Last Post: 06-24-2012, 11:30 PM
  3. Communication Improvements
    By Novakon in forum Novakon
    Last Post: 05-30-2012, 07:43 AM
  4. Any improvements on my X-axis?
    By benjamint76 in forum DIY CNC Router Table Machines
    Last Post: 03-05-2010, 12:26 AM
  5. More Improvements
    By rodneydeeeee in forum Dolphin CAD/CAM
    Last Post: 03-22-2007, 10:40 AM
