Hey All! I am finally to the tramming stage of this mini mill!
I basically took a Harbor Freight X2 Clone (model 44991) mini mill and fit it to the LMS solid kit.. The thing is awesome (See this thread about this:
http://www.cnczone.com/forums/bencht...-make-big.html).
Ok, so I am first tramming the spindle to the table... I made a nice bracket for my Dial Indicator and it works very well.
I measured at the furthest point to the right side of the table, zeroed the dial indicator, and then swept to the far left side of the table. I was out -.004 in my initial measurement here. So... Based on all the articles I have read out there, I placed a shim HALF this size (so, .002) on the right side of the base (as the solid column kit removes the swivel base of the X2 so it has to be shimmed to square it up). Because I had to basically unbolt the column to put the shim in, I just started the process over again the same exact way. I was off -.002 this time... So, I just put a .004" shim on the right side of the column this time. I do a fresh test and I am pretty much zeroed out....
So... I basically put a shim in that was the same size as the amount I was out of tram on my initial measurement...
Did I do this even remotely correct here??? I don't get the whole "adjust it half the distance you are out" idea here that I have been reading about online... This is totally not my experience here for this.
Any feedback on this would be greatly appreciated!
I have poured literally hours into research and setup of this mini mill and I am so close to making the first chips of my life as a hobbyist machinist!
Thanks in advance for the help!
