586,104 active members*
3,403 visitors online*
Results 1 to 6 of 6
    93
    Bridgeport Retrofit
    Deleted advertisement...
    Eric - Moderator
    May 2003
    130
    Retro
    I love my Larkin retrofit on my Bridgeport. It has run everything I've thrown at it so far.
    507
    I like your sunny wall clock!
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Sep 2004
    10
    Hi guys, what software are you running your Bridgeport with on those retrofits.
    May 2003
    130
    software
    The Larken retrofit that I used comes with it's own software called L-Cam.
    There now is a newer version available called Star-Cam that runs in windows.
    You can draw, load DXF files, or direct G-Code input either software.
    May 2003
    130
    Another toy
    Here is another toy made for my daughter on the Larken Bridgeport retro.
    Sorry for pic quality.It's a jewlry box and yes it rotates.All parts were made on the Bridgeport except the pivot shaft.Engraving also done on bridgeport.
  1. Bridgeport EZ Trak Flashdisk question:
    By marx911 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:09 AM
  2. Bridgeport Series II Retrofit
    By Cold Fusion in forum Vertical Mill, Lathe Project Log
    Last Post: 07-01-2007, 02:37 AM
  3. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
  4. Bridgeport Boss Retrofit help
    By moto21 in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2005, 04:32 AM
  5. Bridgeport Retrofit Using Brushless AC Servo Motors?
    By Eric in forum Servo Motors / Drives
    Last Post: 12-05-2004, 04:58 PM
