There's a Sheetcam JOB file in the attached zip folder. It's a very simple cut for illustrating this problem.
I drew a disc with a small hole in the middle. Import into Sheetcam. In Sheetcam I put the small hole on a separate layer and use a drill operation on this layer to mark the hole centre with the plasma torch, all good.
The outer circle is on the other layer and I apply a normal cutting operation.
With just the one part, the hole centres are marked and then the outer cut is done, all good.
Here's the problem: when I want to cut multiples of this part, whether I use copy, duplicate, multiple duplicate, or array, I cannot get the parts to complete one at a time, i.e. mark hole centre & cut outline on part 1, then move to part 2 and repeat. Instead Sheetcam wants to do all hole marking on every part before starting ANY outside cuts.
Can Sheetcam not do this. Tried selecting "Keep Parts Together" in the cutting operation, but obviously this won't help seeing as the hole marking is in drill operation.
Keith
