586,051 active members*
3,751 visitors online*
    Aug 2005
    176
    V2XT DX32 y Overflow
    My machine was Boss 10 and I upgraded to all the hardware and software changes EMI offers.
    The machine has been flawless for few years.
    Running a job today, I was on the last part, y axis in middle of table and I got a +Y Overflow.
    Machine check ok
    Drives enable
    Z will home and then machine shuts down with Y overflow.
    I have no clue.
    Needs some direction.
    Rob
    Nov 2004
    3028
    Re: V2XT DX32 y Overflow
    A Y overflow is that the control sent a command and expected to see a move and did not see a move.
    If it indeed did move and it was not seen, it would indicate a bad position loop (encoder, cable, board, etc.).
    If it did not move, could be mechanical (bearings, gib, ballscrew), motor or drive board (but I would expect a axis drive fault), or no command from control to axis drive board.
  1. V2XT Y+ OVERFLOW
    By nickmenec in forum DNC Problems and Solutions
    Last Post: 05-02-2012, 07:22 PM
  2. Is the DX32 Software for V2XT and Torq-Cut 30 the Same?
    By ss_again in forum Bridgeport / Hardinge Mills
    Last Post: 02-21-2012, 06:19 AM
  3. 1996BRIDGEPORT V2XT DX32 DOS 6.2
    By cortaz in forum Want To Buy...Need help!
    Last Post: 03-02-2011, 09:13 PM
  4. Desperately in need of DX32 V2XT manuals.
    By Tallrs in forum Bridgeport / Hardinge Mills
    Last Post: 04-15-2009, 01:27 AM
  5. V2XT Z overflow error
    By Lasershop in forum Bridgeport / Hardinge Mills
    Last Post: 01-12-2006, 11:05 PM
