586,113 active members*
3,468 visitors online*
Results 1 to 6 of 6
    Apr 2005
    1268
    What is a M3P extension
    Has anyone downloaded and installed the contour shuttlepro pendant program from the machsupport site. The plugin has a m3p extension and when I click "open" as the directions say, windows does not recognize the file extension and the program will not install. What am I doing wrong??? Using windows XP and downloading the software into a scratch directory until I understand it. Help!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Try putting it in the Mach3/plugins directory, and double click the file. It installed here just fine. It deleted the original .m3p file and createds a .dll
    Apr 2007
    7
    Question
    I download the Joystick plug-in from http://www.artsoftcontrols.com/artsoft/plugin.htm It's a m3p file. I put it inside plugins directory I double clicked it, but there is no association with any application so the windows can open it.
    Can you help me with that? How mach3 installs those plugins?
    Apr 2007
    7
    Apr 2007
    7
    Newbie in CNC and MAch
    Jun 2013
    75
    Re: What is a M3P extension
    I know this is old but it was not answer but it somewhat helped me find a solution.
    The M3P is suppose to install when you double click and replace the M3P file with the .dll file plug in, but like a few others, that did not happen for me. It would just ask what program to use to open it and that would not help. I tried changing the extension to .dll but nothing changed. The M3P is suppose to use the M3Plug application in the Mach3 folder when you double click the M3P file, but if it does not, just go to open with... browse for programs and find your Mach3 folder, find the M3Plug application and open the M3P with that, it should install the .dll file and delete the M3P file.
    Oh and this is the link where I found m3p is suppose to use the M3Plug application to install itself which led me to the solution
    SmoothStepper installation problem
    Hope this helps future rookies like me
  1. tray extension
    By ram48 in forum Novakon
    Last Post: 04-24-2013, 02:27 AM
  2. X axis extension?
    By pixel8tryx in forum Taig Mills / Lathes
    Last Post: 06-15-2010, 07:15 PM
  3. How much to cut for y axis extension?
    By kimoyo in forum Charter Oak Automation Support Forum
    Last Post: 06-25-2009, 08:50 PM
  4. X2 Y-axis extension
    By X2cnc in forum Benchtop Machines
    Last Post: 12-17-2008, 04:14 AM
  5. Extension Cord
    By dneisler in forum Welding Brazing Soldering Sealing
    Last Post: 01-14-2006, 02:29 AM
