586,075 active members*
4,228 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > HEIDENHAIN TNC426-Miscellaneous function for spindle (M3,M4,M5) doesn't confirmation
    Sep 2014
    To start the spindle, enter 3 in "Miscellaneous function M =" and press Start CNC. (picture from atach).
    In normal situation, after press Start CNC, display "Miscellaneous function M =3" must disappear.
    In my situation, message "Miscellaneous function M =3" stay on display. To dispear, must press "Manual Mode".
    M3, M4 and M5 not work in programs and program waiting to start / stop the spindle.
    To run program, must start the spindle in manual mode and after the spindle start, can start the program.
    Any other Miscellaneous function work ok, only spindle M3, M4, M5 doesn't work.
    Please, can help me ?
    Thank you very much!
    1121
    Re: HEIDENHAIN TNC426-Miscellaneous function for spindle (M3,M4,M5) doesn't confirmat
    what machine
    May 2012
    6
    I have the same problem. Did you find a solution?
    My Machine is a Deckel Maho DMC 103v
    May 2012
    6
    Quote Originally Posted by bart.oates View Post
    Fixed my Problem.
    http://www.cnczone.com/forums/deckel...ml#post1953962
  1. Zayer milling m/c with Heidenhain TNC426
    By balavishe in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2024, 04:52 AM
  2. Replies: 0
    Last Post: 10-20-2014, 07:13 AM
  3. Replies: 0
    Last Post: 07-24-2014, 05:36 PM
  4. Heidenhain TNC410 and TNC426 or alternative?
    By Stuki-5 in forum BobCad Post Processors
    Last Post: 05-06-2014, 10:11 AM
  5. visualmill Postprosessor for heidenhain tnc426/430
    By latexii in forum Visual Mill
    Last Post: 06-01-2012, 01:39 PM
