586,588 active members*
2,659 visitors online*
Results 1 to 7 of 7
    Dec 2013
    47
    Need help for designing Z-axis
    Hello!
    I have a pair of SBR-16 and a complete 1605 ballscrew, both 300mm in length.
    But i cant seem to design a good z-axis for myself. Anyone who wanna help me?
    I have a 3040 cnc so if you have a good cad/gcode i would be forever greatfull
    Apr 2004
    5741
    Re: Need help for designing Z-axis
    Get a thick aluminum plate you can attach to the Y axis of your gantry or bridge, and screw a rail on each side, making sure they are square to each other. Run the ball screw straight down the middle, fixed at one end in a couple of angular contact bearings, with a bearing on the other end that lets it float a little. Make a motor plate with holes corresponding to the holes in your motor's faceplate and center it on the fixed end of the screw, then attach it to the plate with the rails on it. Get another aluminum plate and drill it for the spindle mount you're using, and also on the sides for the trucks that ride on your rails, spaced so that they will give good support without restricting the range of travel too much, and in the middle for the carrier that holds your ball screw nut. Put it all together and you've got a Z axis.
    Andrew Werby
    Website
    Dec 2007
    2134
    Just google images of Z's or check out the usual suspects on Ebay, it's a pretty tried and tested design so there's no "copying" issues as such. In order to align the parts though, get some good clamps that will reliably hold stuff aligned while drilling, etc.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Dec 2013
    47
    Quote Originally Posted by awerby View Post
    Hello and thanks for the reply!
    Thats sounds like a good option. Do you have a visual representation of what you described?
    Apr 2004
    5741
    This is a lot like what I was describing: MRC CNC Z axis - AutoCAD, STL, STEP / IGES - 3D CAD model - GrabCAD except that the motor doesn't seem to attach quite right.
    Andrew Werby
    Website
    Dec 2013
    47
    I have been looking at a design like that, but it require that i make a holes likes this: Attachment 254368
    If not i cant attach the lower two bolts on the nema 23 motor.
    Apr 2004
    5741
    It will work a lot better if all the holes in the motor faceplate are bolted down to the plate on top of the axis assembly. Just make that plate big enough to have all 4 holes. It doesn't look like the axis will travel much past there anyway without coming off the rails.
    Andrew Werby
    Website
  1. help with designing a balluster and using an a axis with vcarve pro
    By wmpinion in forum PhotoVCarve and VCarve Pro
    Last Post: 05-15-2013, 02:15 AM
  2. CAD Designing
    By ActiveLife in forum Uncategorised CAD Discussion
    Last Post: 07-07-2012, 11:14 PM
  3. need help designing this 6'x6'
    By generalee in forum Open Source CNC Machine Designs
    Last Post: 12-23-2011, 09:14 PM
  4. Designing gears to be cut with 3 axis CNC
    By frStudent in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2011, 07:46 PM
  5. help designing
    By alfonsonog in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2007, 07:23 PM
