586,103 active members*
3,877 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Spindle making grinding/humming noise
    Oct 2014
    Unhappy Spindle making grinding/humming noise
    Hi Everybody,
    I just joined CNC Zone, and need help. When my machine hits anywhere between 1800 - 2200 RPM I start to get a grinding noise going on. If I override the speed it sounds fine, but I need certain tools to run in that RPM range. Anybody have experience with this?
    I'd appreciate any help or tips...
    Keith
    Feb 2010
    1184
    Re: Spindle making grinding/humming noise
    Quote Originally Posted by machinisto View Post
    Hi Everybody,
    Keith
    For future posts, you will want to provide details about your machine setup regarding age, model, options, etc or anything that may help with the situation at hand.
    Regardless, any grinding noises are not good and most likely suggest either bad bearings or gear box if you have one. It's best to fix this sooner rather than later, because eventually it will get worse and or seize up altogether and that always happens at the most inopportune times.
    If you have more questions, please be specific and provide as many details you can in order to give the best help we can.
    Good luck!
  1. Stepper motor noise and grinding
    By motion86 in forum Stepper Motors / Drives
    Last Post: 01-23-2014, 10:31 AM
  2. Humming noise coming out of power box on back of series 2 BP
    By Pritch in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2013, 02:20 PM
  3. BF30 Grinding Noise
    By tef9 in forum Benchtop Machines
    Last Post: 09-07-2012, 08:37 PM
  4. Motor Humming Noise?
    By Dman in forum Hobbycnc (Products)
    Last Post: 11-10-2008, 01:03 AM
  5. Humming noise in Car Starter motor
    By ramee20374 in forum CNC Machine Related Electronics
    Last Post: 10-25-2008, 05:08 PM
