Re: table top cnc
Originally Posted by
50chevy
I have one of the 6040's and would probably consider them the best value machine available on the market at the hobbyist level, despite the need and extra cost to swap the crap controller that comes supplied as standard, and the power supply. Waranty of course is zero, but as you would realistically only care about the mechanics of the machine, any issues would immediately be obvious and covered by Ebay/Paypal's policies. I've used mine quite happily to machine 38-43mm thick aluminium blocks for spindle mounts, albeit at very fast speeds and light cuts. If you can more or less water proof the table to any degree, and add a Kool-Mist or similar, you'd get quite reasonable performance and results.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
