586,089 active members*
3,913 visitors online*
IndustryArena Forum > CAD Software > Solidworks > can't rebuild the sketch
    Jun 2010
    86
    Hi
    I draw a 2D sketch that has more than 2400 lines and spline.
    I get an expert for another software but splines are not with high quality when i get save as by DXF or DWG file format, it is broken. so i decided to make it extruded and then get a 2d export by DWG or DXF file format, by this method we will have 2D smooth curve by DXF file format, but i can't rebuild sketch and solid works give me an error .( please sea attached picture)
    i check the sketch by check sketch by feature and solid works tell me, sketch file have 386 problem but when i use trim corner solid works tell me : " the entity already make corner with selected entity " i also get zoom in the corners and i don't saw any problem.
    What should i do to fix this problem ?
    I have a 2d spline sketch that can't get a high quality expert for another software.
    I test " high quality expert" option on the DXF expert option but no change.
    Please help me
    Thank you
    Jun 2008
    562
    Re: can't rebuild the sketch
    Can you post the sketch? You probably have a small gap(s) or overlapping lines hidden somewhere.
    Mike
    Mar 2008
    683
    SW is telling you there are gaps. They need closed.
    What I would do... I would leave that sketch alone and not waste the time trying to repair it. Use it as a base and pull information on another sketch right on top of the original sketch. Break it in to several smaller sketches and regions so you don't have so much info on one sketch to hunt for. Draw clean lines and splines on top and you will have smaller clean sketches with which to create your extrusions. Once you get everything extruded join the bodies and hide the original sketch.
    You can use the "select chain" option to help find non connecting corners.
  1. V25 Arc Sketch Errors
    By tubeguy in forum BobCad-Cam
    Last Post: 10-19-2012, 09:54 AM
  2. Trying to Sketch on the Right Plane.....
    By Stampede in forum Solidworks
    Last Post: 08-23-2012, 09:59 PM
  3. 2Dsketch, can't use it like 3D sketch why is that
    By Spencer myers in forum Solidworks
    Last Post: 01-28-2012, 10:40 PM
  4. Sketch On the O.D. of a Cylinder
    By stang5197 in forum Solidworks
    Last Post: 09-03-2008, 02:49 AM
  5. Profile a Sketch
    By djzepp in forum Autodesk
    Last Post: 12-05-2006, 08:00 PM
