586,075 active members*
3,937 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Rotary axis battery problem is driving me nuts!
    Dec 2010
    126
    We have a 2010 Fadal (Mag-Fadal, FANUC Controller). The backup battery doesn't always hold charge perfectly so every month I'll pull the battery and charge it out of the machine. Normally the 307 alarm for X,Y,Z warns me when it is time to do this.
    Recently I have been getting a 307 alarm for the A-Axis as well. This means the "APC" signal constantly flashes so when the X,Y,Z battery gets low we don't always realize it. We have a SMW Accu-Rock 4th axis with the additional FANUC drive box in the electrical panel. The battery for the X,Y,Z axis is plain as day when you open the electrical panel, but I cannot find the battery for the A-Axis anywhere! There is nothing external to the drive for the 4th axis and nothing on the 4th axis itself. Does anyone know where to find this battery so I can replace it (along with the failing XYZ battery) and quit worrying about losing the machine parameters during long weekends or if I forget to check the battery condition?
    I can answer any other questions you may have, just let me know. Thanks.
    Dec 2010
    126
    Re: Rotary axis battery problem is driving me nuts!
    Nevermind...found it! It is right in plain sight, sort of. It is connected to the bottom side of the rotary axis control unit behind a large bundle of wires. I had to do a little digging to see it clearly.
    Thanks for stopping by and reading this anyway!
  1. Alarm Driving me nuts
    By zschary in forum Hardinge Lathes
    Last Post: 01-19-2013, 10:31 PM
  2. A220 Issue that is driving me nuts
    By SirDenisNayland in forum CNC Swiss Screw Machines
    Last Post: 06-11-2012, 12:59 PM
  3. Scale problems are driving me nuts!
    By austexjwlry in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-27-2009, 04:42 PM
  4. Plunge Feed driving me nuts
    By DRP in forum Mach Software (ArtSoft software)
    Last Post: 09-12-2007, 04:53 PM
  5. Nuts are driving me nuts!
    By Cold Fusion in forum Community Club House
    Last Post: 06-13-2004, 05:40 AM
