586,043 active members*
3,926 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > "EX1160 spindle rotation down alarm Fanuc series oi-md
    Oct 2014
    Exclamation "EX1160 spindle rotation down alarm Fanuc series oi-md
    Dear All
    Now we have problem about cnc milling.
    This is code show in the machine "EX1160 spindle rotation down alarm"
    Please see the attached file.
    The problem is....
    1.PCB .It short after that it burn.
    2We order new part .
    3.We put in PCB to the machine araedy.
    4.But,On the monitor show alarm.
    We look in handbook for help us but,Not have this code (EX1160 spindle rotation down alarm)
    We hope maybe you can help us.
    Do you have solution? for help us.
    1.Fanuc series oi-md
    2.Hwacheon vesta 1000
    Attachment 254846
    Attachment 254848
    Feb 2005
    69
    Re: "EX1160 spindle rotation down alarm Fanuc series oi-md
    Check your 1 amp fuse on the I/O module. There should be a green light on. The first message is a hard over travel and will not let you clear e-stop. Is z-axis actually on the hard limit switch? If not is is probably the 1 amp fuse. The second message is generated by the machine tool builder, not a fanuc alarm. You will have to find the address for this alarm and search it in the ladder logic to find what is causing it.
  1. doosan lynx 220c spindle rotation alarm no. 2028
    By varskmachinellc in forum Daewoo/Doosan
    Last Post: 11-01-2022, 10:55 AM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 11M spindle rotation is backwards
    By ddcarter in forum Fanuc
    Last Post: 03-28-2012, 02:14 PM
  4. Replies: 0
    Last Post: 11-25-2011, 12:32 AM
  5. Interact 2 Series 2 Spindle "no start"
    By mally in forum Bridgeport / Hardinge Mills
    Last Post: 09-18-2010, 01:09 PM
