586,036 active members*
3,760 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > HDS Spindle making noise after shaft kit replacement
Results 1 to 7 of 7
    Feb 2007
    25
    Wondering if anyone has experienced the noise I have with my HSD 929 spindle. I have just replaced it with a new shaft kit so the bearings should be fine. I did notice that with the old shaft that there was a similar sound at start up/warm up but then it would disappear. This leads me to think that there is an issue with the housing unit. The sound is quite tinny and sounds as if something is loose (at the 30 second mark of the video it seems to correct itself slightly) but I've refitted to make sure that all bolts are secure so there shouldn't be a problem there.
    Any advice would be greatly appreciated.
    Cheers
    IMG 1698 - YouTube
    Service SCM BR Guest
    Re: HDS Spindle making noise after shaft kit replacement
    Where is the spindle? I,m in Brazil.
    Via iPhone of the Tapatalk
    15362
    branchy
    Do you have the correct amount of Grease in the Bearings, too much Grease can cause noise's at start up
    Mactec54
    Jan 2007
    1795
    that sharp noise at start,,,, little weird..
    like a washer loose and getting up to the speed.. im not saying anything were loosen.. I just try to say an example..
    by the way, what rpm it has on the video?
    15362
    Quote Originally Posted by victorofga View Post
    That's the noise a Bearing can make when it is skidding, from having to much Grease in it, or the Bearings are to tight a fit in the Housing or on the Spindle Shaft, It most likely is to much Grease, because the noise goes away, after it has pushed the grease out
    Mactec54
    Hey mate,
    Did you ever solve this issue? i have the same router (procam mityboy) and the exact same problem.
    Any help would be appreciated,
    Cheers,
    15362
    Quote Originally Posted by joeldouglas View Post
    Hey mate,
    Cheers,
    Don't hold your breath for a reply this was posted in 2014 5 years ago you may be better off to start a new Thread
    Mactec54
  1. Spindle making grinding/humming noise
    By machinisto in forum Haas Mills
    Last Post: 10-21-2014, 09:05 PM
  2. Replies: 5
    Last Post: 09-17-2011, 07:57 PM
  3. Z-Axis making noise
    By 2Bits in forum Linear and Rotary Motion
    Last Post: 06-14-2011, 02:15 AM
  4. motor making noise
    By kasari in forum CNC Machine Related Electronics
    Last Post: 01-17-2010, 01:33 AM
  5. Lead screw making noise
    By clembrant in forum Linear and Rotary Motion
    Last Post: 01-27-2007, 04:48 PM
