586,108 active members*
3,107 visitors online*
    Sep 2006
    Question help with parametric programming on 840c
    I am trying to program an 840c to use conditional statements. I know how to do this with a fanuc, but am new to programming the siemens control. The following is an example with fanuc program any help converting would be appreciated. thanks in advance.
    N005 R500=1
    N010 IF R500 EQ 1 GOTO 20
    N015 IF R500 GT 1 GOTO 25
    N20 M98 P2
    N25 M98 P3
    Apr 2006
    109
    I might try using this symbol < , >that might work.
    Sep 2006
    mmachining, never seen <> used in a program
    as a quick follow up below is the correct code,
    N045 R600=1 (INPUT VARIABLE FOR PART NUMBER)
    R601=1 (1= OUTER RING 80 HOLES)
    R602=2 (2= INNER RING 60 HOLES)
    R603=3 (3= TOP OUTER RING 2 HOLES)
    R604=4 (4= TOP INNER RING)
    R605=5 (5= BOTTOM OUTER RING)
    R606=6 (6= BOTTOM INNER RING)
    N050 @121 R600 R601 K60
    N055 L20031
    N060 @121 R600 R602 K70
    N065 L20032
    N070 @121 R600 R603 K80
    N075 L20033
    N080 @121 R600 R604 K90
    N085 L20034
    N090 @121 R600 R605 K100
    N095 L20035
    N100 @121 R600 R606 K110
    N105 L20036
    N110 M30(END OF PROGRAM)
    Dec 2006
    310
    ELB Perfect-Future B10 CNC with Siemens 840 C
    Dear All,
    Good Morning to u all !!!!!!!!!!!!
    Pl note that subject machine was ok till yesterday & now we are getting Alarm 3000 1 N400 General Program Error
    a) Checked SPF 152, which is run on this machine & found
    N0400 @121 R1917 K1 K0410
    In single block, we can see current block Protected cycle SPF 1000
    Program Pointer
    SPF 152 1
    SPF 1000 P1 N325
    b) Even in case of SPF 151, SPF 101 also we get same error
    Please advice at [email protected]
    Best Regards,
    M. Rishikesh
