586,080 active members*
3,719 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > bobcad V26 not giving z moves in with contour ramping
    Oct 2009
    56
    Hi all I have a problem with Bobcad V26 not producing Z helical moves in code when contour ramping but shows it doing so in simulation. I suspect the Post Processor attached.
    Any Help would be appreciated
    The more I learn, the more I find there is to learn
    Regards Nick
    Dec 2013
    290
    Re: bobcad V26 not giving z moves in with contour ramping
    Your machine does not support helical ramping.
    Go to your feature, and under posting select line moves. It defaults to arc moves.
    Dec 2011
    295
    Look in paragraph 64 mine reads
    64. Arc move xy.
    n, g_arc_plane, g_arc_move,x_f,y_f, z_f, arc_center, feed_rate
    Bet you dont have z_f
    should work
    add x_f to paragraph 65 and y_f to 66 incase you use slice plainer with odd lace angles with arc moves.
  1. Ramping End Mill using BobCad
    By jimbogrif in forum BobCad-Cam
    Last Post: 06-03-2013, 06:44 PM
  2. Contour Ramping V24
    By Bear21211 in forum BobCad-Cam
    Last Post: 02-04-2013, 03:36 PM
  3. Problem using Deform Contour in BOBCAD V24
    By rbarry1068 in forum BobCad-Cam
    Last Post: 08-29-2012, 09:58 PM
  4. V24 profile contour ramping will not run finish
    By gizmo_454 in forum BobCad-Cam
    Last Post: 01-14-2012, 12:18 AM
  5. BobCAD; steps on ramping?
    By inthedark in forum BobCad-Cam
    Last Post: 04-07-2004, 02:48 PM
