Hey friends,
This is Lucy from Jinan Consure Electronic Technology Co.,Ltd which is specialized in Laser Engraving Cutting Machine, Laser Marking Machine, CNC Router.
Let us share with you our CS4040 40W Laser Engraver Cutter for hobby use:
Machine Applications:
Proper Materials: Acrylic, Crystal, Bamboo, Cloth, Fabric/Denim, Fiberglass, Glass, Laminated Plastic, Leather, Marble, Plastic, Paper, Rubber, Wood, MDF, Marble, Anodized Aluminium, Coated Metal, etc.
Application: Sign Making, Nameplates, Awards, Badges and Tags, Gift Engraving, Model Making, Architectural Model, Image engraving, Fabric Engraving and Cutting, Jeans Image, Hollowing on Leather, Notary Seals, Rubber Stamps, Souvenirs, etc.
Technical Parameters:
Model CS4040 Working area 400*400mm Laser Power 40W Optional 50W, 60W Laser Type CO2 sealed glass Laser Tube Engraving speed 0-600mm/s Resetting positioning accuracy <0.01mm Minimum Shaping Character 1×1mm Power supply 220V±10% 50HZ or 110V±10% 60HZ Controller AWC608 laser engraving&cutting controller Software supported ArtCut, CorelDraw, PhotoShop, AutoCAD Graphic format supported PLT、DXF、BMP、JPG、GIF、PGN、TIF Water Cooling(Yes / No) Yes Machine Packing Size 990X850X490mm Machine Gross Weight 90KG Assistant Equipment Water pump, Air pump, Exhaust fan
Working Video:
https://youtu.be/P5JAlDhTaMk
Lucy Xiao (Sales Manager)
Wechat/Whatspp/Mobile:0086-18254116182 |Skype: huanjiaoxiao
Web.: www.jncslaser.com| Email: [email protected]
Tel.: 0086-0531-58618208 | Fax.: +86-0531-85909329
Add.: No. 68 Dikou Road, Tianqiao District, Jinan City Shandong China.
